  • 1.  Media store autoplay on memory recall
    Posted 09-27-2013 13:17
    Hi all.Is there any posibility to autoRun a media animation(loaded to a media channel) after recall a specific memory? For example I have an animation sequence used for backgroud in pgm and that animation is set to loop. If I recall another memory with another background animation and then recall the the memory with first background, that background just loaded without autorun.
  • 2.  RE: Media store autoplay on memory recall
    Posted 09-27-2013 14:25
    Is the auto play attribute set to yes and then saved? If you just toggle the setting but don't save it then when it loads it will recall the attributes.
    Make sure you have those parameters set for the attributes and then save the memory.
