  • 1.  Multiviewer/Monitor Wall Layout Sheet
    Posted 07-26-2013 14:07
    We love our Carbonite, Ross's tech support and all of the great features you guys work so hard to give us. As a vendor one thing I think would be very helpful is if you could generate a PDF with all the optional monitor wall layouts in enough size to be able to write labels in them. This is something that we could give to clients in advance to select their layout and configuration, labels and busmapping so we could pre-build the wall and mapping for directors/TD's. With the new update to our carbonite and dashboard we can now build the wall from our engineering area in the back of our truck but having to show our directors all the options still occupies a lot of time during pre-pro. Just a thought for what would be some nice supplementary forms with your other documents. Thanks.
  • 2.  RE: Multiviewer/Monitor Wall Layout Sheet
    Posted 07-26-2013 16:27
    Hi Josh,
    Thanks for the Feedback
    We will see what we can work on for you.
  • 3.  RE: Multiviewer/Monitor Wall Layout Sheet
    Posted 10-30-2013 00:11
    Is there any update to this Les? It would also be something that would cut down on time for our engineering staff as well. Thank you!
  • 4.  RE: Multiviewer/Monitor Wall Layout Sheet
  • 5.  RE: Multiviewer/Monitor Wall Layout Sheet
    Posted 10-30-2013 00:24
    All of the Layouts are in Page 10 of the Manual in the current v7.3 release. Downloadable from the website.
    This is a High Res PDF. You can Cut and Paste them and Increase the Size with acceptable Results.
    Otherwise you will have to wait for Version 8 and we can try our best to add it to the documentation then.
  • 6.  RE: Multiviewer/Monitor Wall Layout Sheet
    Posted 10-30-2013 00:51
    Here is an example of just the HD(same for SD in SD Mode) layouts. I did it pretty quick so if you want the HD in SD mode then you can just do the same -- copy out of the manual paste into a document program (Pages in my case) and then enlarge.
    Hope this works for you.
    https://www.dropbox.com/s/tvb8ny9qun65bm0/HD%20Layouts%207.3.pdf
