I currently am using the only HDMI output for the multiscreen monitor. I will try to set it up to strip the ANC DATA. Audio, well, i was just going to take a BUS send from the sound board to a recorder and then the video out from the switcher converted to hdmi ( the recorder doesn't have SDI input), but now it seems they want to send the signal to multiple monitors in the building, which means I am going to have to get something that will combine the audio from the sound board with the video signal, hopefully something that I can control the delay to match video and audio timing, haven't started any research on the piece of equipment yet, any suggestions. I will be using SDI to get from the booth to the monitors (HDMI monitors, so each will need a convertor) in the building.
