When I try to add a device summary or editor to a custom panel, it doesn't work. By following the instructions below from the manual, I am not getting a dialog box to appear in step 3. Instead, the device opens in full screen mode. I am using Dashboard 8.1.1 on a mac. Thoughts? To add a device editor or device summary:
[FONT=Helvetica] 1. With the CustomPanel open, enter PanelBuilder Edit Mode.[/FONT]
Tip: To enter Edit Mode, press CTRL+G.
[FONT=Helvetica] 2. In the DashBoard Tree View, locate the device.[/FONT]
[FONT=Helvetica] 3. Drag and drop the device from the Tree View onto the CustomPanel.[/FONT]
The Insert into Component dialog box appears.
[FONT=Helvetica] 4. Select one of the following:[/FONT]
"¢ Device Summary "” shows detailed device summary information, and may include a link for opening the
device's editor. The link appears only if the device has an editor.
"¢ Embedded Editor "” shows the default device monitoring and control interface for the device.
"¢ Status Dot "” shows a color-coded dot to indicate device status.
[FONT=Helvetica] 5. If you want to include the device's label, select Show Label.[/FONT]
Tip: Alternatively, you can create a custom label later instead of importing the device's label.
[FONT=Helvetica] 6. Click OK.[/FONT]
[FONT=Times][SIZE=10px]The device editor or device summary appears on the CustomPanel.
Jeff[/SIZE][/FONT]
