  • 1.  Controlling an Evs Spotbox
    Posted 02-19-2015 07:16
    Can I connect a Carbonite to an EVS through a lance or some other way to use for clip and replay transitions?
  • 2.  RE: Controlling an Evs Spotbox
    Posted 02-19-2015 16:16
    TJ:
    I know you can connect the lance to the GPIs of the Carbonite in order to give you the same ability as manually pressing the function keys on the lance. IE.. Play, Loop, Jump Reg #s, Stop, Recue.
    We had a lance controlling a fast forward at one point in time.
  • 3.  RE: Controlling an Evs Spotbox
    Posted 02-20-2015 00:42
    TJ and Gordon,
    In version 8 we added PBus support so you should be able to use a Lance or DNF with the Carbonite.
    In customs insert the PBus recall iID and then send the trigger ID after the appropriate pause for the cue.
