You will probably need to make sure you are running DashBoard 7 and then if you can send me screen shots of what is wrong that would help.
On the Setup page I left notes about what needs to be enabled.
The Shotbox allows you to enter the time code you want to cue and the ID number beside is the RossTalk GPI number that you send. On the transport page (as per the notes in the Setup page) Play is 99 and Stop is 98 etc.
You setup a rosstalk device to send messages to the IP address of the computer running this grid file. It will interpret the GPI commands you send to it to trigger these "buttons" which will then convert that into BVW-75 commands that will be sent over IP to the IP to Serial device translator.
