  • 1.  Camera CCU tally when Black is on PGM
    Posted 10-21-2013 03:53
    I did a show last week and instead of doing the normal rollout from a tape machine I decided to use live shots to end the show. After I faded to black, the video engineer asked me to clear camera 1 tally, so he could turn the CCU off. I informed him I had black on PGM. He believes I had camera 1 online somewhere. So, I took black on ME1 and ME2 both PGM and PST, (ALL keys were off - and Camera 1 was never used as a key during the show) he said the CCU was still showing a tally.
    I cleared the tally by cutting to any source other than black. When I cut back to black the CCU tallied again.
    Thoughts?
  • 2.  RE: Camera CCU tally when Black is on PGM
    Posted 10-21-2013 14:27
    Hi Gordon,
    Sounds like someone assigned a Tally to Black :)
    In the Tally menu you can (Config - Next - Tally) you can setup Multiple Events for every Tally. So it sounds like someone was in that menu and added an Event that the tally used for Cam 1 will also tally when Black is selected.
