I have a client that has sent material (mov files) to me and I am able to play them from the Blackstorm, they work correctly as far as the fill and matte are concerned. The problem is they left about a second or two of dead time, and not the same amount for every file, before the effects and I have no means to edit the files.
I have the blackstorm set to use "Use Server-entered Trim points" and I am controlling it to cue / play with a Carbonite 2 via custom controls. The manual states "Regardless of this check box being selected, the BlackStorm Server always uses trim points received from an upstream controller." Is not the switcher an upstream controller?
I have set the in and out trim points of the effects (mov files) and while I am able to manually drag them to the player they cue up correctly to the trim point I assigned. However, when I use the switcher to load the file and cue / play the same file that worked properly before it now goes to the head of the file and cues up and NOT the trim point assigned, even though when I look at the player I see the trim point is there. I have about 75 effects for one show (one client) and I do not have time while on-air to manually cue each effect since any of the effects could be used at a moments notice.
With the switcher recalling the file using the custom control, there is a delay (depending on how many frames the original file has before the effect is seen). This is greatly affecting the show, getting to / from sources and missing live action.
Am I missing something?
Can what I need to do even be done?
My custom control dialog is:
Aux 5 (sends audio out to aja) "“ Blackstorm 1
ME2 Key4 "“ State OFF
ME2 Key4 (selects key input since I change this a lot during the show) "“ Blackstorm 1
Cue (file name)
Pause 3 frames "“ (have noticed the Blackstorm works better "“ time for it to think)
Play (file name)
Pause (amount of frames before the effect "dead time")
ME2 Key4 "“ State ON
Pause (amount before under cut)
Cut
Pause (amount of frames the effect takes to finish the move)
ME2 Key4 (select source "“ telestrator)
