Peter, here is how I do it:
First a couple of things to know:
1.) The
"SCOREBUG" is an external device, sometimes it is CG2, depends on the show or if the BUG fails to operate properly.
2.) I use Emems to cut my cameras on MLE2 (PGM) - When I store the Emem the Keyers are Key 1 - CG 1 (OFF), Key 2 - CG 2 (OFF), Key 3 - BUG (ON), Key 4 - Xpression (OFF). M/E Trans Rate is 10 frames
3.) I store each each camera to their corresponding number on the keypad.
IE (Bank #0 Emem# 1 - Cam 1, Emem#2 - Cam#2...and so on)
4.) On Bank #1 - I store all the cameras as above but have the keyers are set as:
[I]
this is my 'emergency scorebug' scenario[/I] --- NOTE Key 3 changed ---
Key 1 - CG 1 (OFF), Key 2 - CG 2 (OFF), Key 3 - CG2 (ON), Key 4 - Xpression (OFF).
5.) We run the Media Player(s) and the Xpression audio through an AJA then the AJA output goes to the audio mixer. Aux 5 is used to route the various signals to the AJA
NOTE:
Assign each specific media store/player as an ANC data source (that is the embedded audio) to the MultiViewer outputs. (via dashboard is the easiest way)
MV1 (MultiViewer 1) = Media Player 1
MV2 (MultiViewer 2) = Media Player 3
6.) Media Player 3 - Used to recall the 'watermark' TGA file artwork from the USB attached to the switcher.
7.) The Replay ON / OFF artwork comes from the Xpression
8.) I manually select which tape deck I am going to replay on PST.
:01 sec REPLAY ON CUSTOM CONTROL:
AUX 5 - Xpression
Xpression "“ (LOAD clip to be used)
Pause 5 frames
M/E2 Key 4 - Xpression (I re-select the source as Xpression)
M/E2 Key 4 "“ ON
Xpression "“ RUN command
Pause 15 frames
M/E 2 CUT
M/E2 KEY 3 - MediaPlayer 3 (Load 'watermark' TGA file)
Pause 15 frames
M/E2 Key 4 "“ OFF
:01 sec REPLAY OFF CUSTOM CONTROL:
AUX 5 - Xpression
Pause 5 frames
M/E2 Key 4 "“ ON
Pause 15 frames
M/E 2 CUT
M/E2 KEY 3 - SCOREBUG
Pause 15 frames
M/E2 Key 4 "“ OFF
[I]
'EMERGENCY 'SCOREBUG' SCENARIO[/I]
I copy ALL my Custom Controls from M/E2 Bank 1 (normal operation) to Custom Controls from M/E2 Bank 2 (EMERGENCY operation) to the same locations --- I edit the Replay OFF Custom.
:01 sec EMERGENCY REPLAY OFF CUSTOM CONTROL:
AUX 5 - Xpression
Pause 5 frames
M/E2 Key 4 "“ ON
Pause 15 frames
M/E 2 CUT
M/E2 KEY 3 - CG2
Pause 15 frames
M/E2 Key 4 "“ OFF
Either operational state I am in --- ONLY Key 3 source is changed. (that is where I 'watermark' my replays)
If you need any help feel free to message me
