We currently have several custom controls set up to cue up specific animations from Xpression within its sequence.
The only issue is that each time the animation is triggered, the operator's sequence is automatically cued to the particular animation's position within the sequence.
Is there a way to "un-pin" said animations so that the are called up and played through Xpression that does not move the operators spot in the show sequence??
P.S. Wasn't sure which sub-forum to post this under as this concerns both the Carbonite Black and Xpression.
