  • 1.  Switcher stuck in upgrade mode
    Posted 11-16-2015 17:46
    I am trying to upgrade our switcher to v11.1 from v10.
    Its starts the process and gets all the way to starting upgrade, then its says upgrade failure. Now, its frozen there and won't do anything.
    Suggestions?
  • 2.  RE: Switcher stuck in upgrade mode
    Posted 11-16-2015 17:56
    Probably not enough room on your USB.
    You need 2 GB free space.
    Format a USB fat32 then only put in the upgrade. Then run a force upgrade.
  • 3.  RE: Switcher stuck in upgrade mode
    Posted 11-16-2015 18:01
    Did that; now is stuck on Waiting for USB mode
  • 4.  RE: Switcher stuck in upgrade mode
    Posted 11-16-2015 18:38
    There is a switch called Upgrade.
    Hold it down then turn on the frame keep it held till you see the yellow upgrade led come on -- about 10 seconds.
    Ps tech support is available at 613-652-4886. If your having problems that is a better avenue for these types of urgent issues.
  • 5.  RE: Switcher stuck in upgrade mode
    Posted 11-16-2015 20:02
    Thanks for the tips. Nothing is working, so calling tech support now.
  • 6.  RE: Switcher stuck in upgrade mode
    Posted 04-29-2016 08:23
    Hello brtaus,
    Did the tech support help to resume your switcher? I also plan to upgrade my Carbonite from V9.10 to V11.10.......
    Thanks for sharing.
    regards from Jackie
