  • 1.  Split screen from chromakey to chromakey
    Posted 12-03-2012 16:09
    Hey, is there any way to split screen from one chromakey shot to another chromakey shot? Right now, we have a crosspoint on the switcher that allows us to get the MLE1 Clean, so the current build is key 1 chromakey, key 2 is DVE resize of chromakey shot, and Key 3 DVE of video. Is there any way we could wire to a preview of MLE1 so I could resize that?
  • 2.  RE: Split screen from chromakey to chromakey
    Posted 12-05-2012 16:31
    Hi Sarah,
    You will need to wire an output to an input to allow you to get the PV back into the switcher for use in this manner. you will need to give up an output and an input to make this happen assigning MLE 1 PV to an output and wiring that back into an available input on the switcher.
    Note that you will now have all 4 keyers tied up and you will have to ensure that the 2 box consumes the whole screen or that you have a Graphic overlay that is coming form MLE 2 Keyers.
