  • 1.  Keying a DVE
    Posted 09-12-2018 14:19
    Wondering the best workflow to be able to key a dve after it has been moved and resized. I have a parent paging system that gives me white letters on black background via sdi. It is generated from a backend website that our staff types numbers into. It goes full screen to certain screens and I need to key out the black and put in the corner of a live feed for our lobby TVs. In essence, you don't see anything unless the number is displayed. It's running on a raspberry pi, so limited on what I can do with the image coming out.
    I'm wanting to use as few resources as possible. I'm running the new Solo 13U, so current plan is using one minime to DVE it and then feed it into the other minime to key out.
  • 2.  RE: Keying a DVE
    Posted 09-12-2018 14:36
    I was holding down DVE then click a Key option. I should have done the reverse. Hold down your Key (Self Key, Auto Select, Chroma Key) and then click DVE.
