Also have a question regarding View Control. Am having trouble correctly lining up the display from Dashboard with the video windows from the Carbonite Multiviewer. Am just using a straight BM HDMI>SDI converter and I just can't seem to adjust the Dashboard ViewControl Window correctly to line up - is there something I'm missing or does the converting system I'm using need more functionality (i.e a little bit of scaling?) The Mutiviewer windows are approximately in the right place but it seems as if I could get rid of the Dashboard Menu tab then it would fit....this seems like something really basic that I'm missing. Can you help?(Edit: just found my mistake. Disregard this post...)
