  • 1.  DVE Sequence with Carbonite
    Posted 04-27-2016 12:49
    Hy everyone,
    I now that it is possible to fly DVE Pictures with a CC. But every time I program my CC and Change the DVE size and position it changes the position by a cut and not with an Effekt.
    How can I do it with an Effect like in your Introduction Carbonite MiniMes video.
    Thanks GÁ¶tz
  • 2.  RE: DVE Sequence with Carbonite
    Posted 04-27-2016 13:24
    When you are creating that "State" for the position what you need to use is the Effects Dissolve type. This will then interpolate at the EFF DIS rate that you also stored with that STATE to move to this position(s). Just remember that you need to allow for the Time of the Effects Dissolve by adding a Pause after for at least the duration of the move plus 1 frame before adding the next move or event in the CC. This duration could also be much longer if you want it to go to that position and then stay there for a set period of time. If you want to be able to manually advance to the next position then you should use the HOLD after the STATE as this will then require you to RESUME the CC to advance to the next position.
