  • 1.  Carbonite Black Plus Multiviewers
    Posted 05-22-2018 08:55
    Just to check if i am understanding this right;
    The Carbonite Black Plus has a total of 5 multiviewers, but only two of them can be configured, the remaining three are fixed layout and fixed sources on dedicated outputs?
    Correct?
    regards
    Lars Petter
  • 2.  RE: Carbonite Black Plus Multiviewers
    Posted 05-23-2018 22:50
    No not totally correct.
    MV 3, 4 and 5 can have any layout you like -- same ones as MV1 and MV2. However MV3 only has access to Inputs 1-12 and outputs 11-14. MV4 only has access to inputs 13-24 and outputs 15-18. MV 3 only has access to Inputs 25-36 and outputs 19-22
  • 3.  RE: Carbonite Black Plus Multiviewers
    Posted 05-24-2018 08:47
    Thanx, now i got it.
    LP
