  • 1.  Rotate output
    Posted 03-04-2016 13:01
    Hi i am looking to see if the Carbonite can rotate a source 90 degrees. can this be done using DVE or is it even possible.
  • 2.  RE: Rotate output
    Posted 03-04-2016 15:21
    Carbonite are 2D DVE so there is no Rotation. If this is for Monitors on Set that you want to turn sideways Apantac makes products for doing this.
