  • 1.  MLE2 Follow Program Bus
    Posted 12-04-2012 16:58
    I am setting up a carbonite and need the MLE2 Bus to follow the program bus. The second MLE is controlling a live stream while the main bus is controlling in house monitors. At times, I need them linked. I have been looking through here and online but have not had any luck. Any help is greatly appreciated. Thanks.
  • 2.  RE: MLE2 Follow Program Bus
    Posted 12-04-2012 23:45
    Could you just set MLE1 as a crosspoint on MLE2, and punch that up when necessary?
  • 3.  RE: MLE2 Follow Program Bus
    Posted 12-05-2012 16:26
    PGM is MLE 2 ;) But I think Greg picked up what you were looking to do.
    So there is a feature that allows you to flip the panel Row assignment -- putting MLE 1 at the Bottom and MLE 2 at the Top. Now you can switch in front of you while putting the PGM MLE at the top of the panel. Just select MLE 1 as the source in the PGM MLE and then Cut on MLE 1. When you need them to be different breakaway on MLE 2 to your source. IN this case you are now probably "flipping" your feeds so that MLE 2 feeds the stream and MLE 1 feeds the house. Same thing just "different".
  • 4.  RE: MLE2 Follow Program Bus
    Posted 12-05-2012 19:51
    Thanks for the quick response. I'll give it a try. Thanks guys.
  • 5.  RE: MLE2 Follow Program Bus
    Posted 02-15-2013 02:13
    Follow-up question to this configuration...
    How can I get the multiviewer green tally boxes to show up now, it seems the MV is still following MLE 2 preview. Is there a way to change that?
    David
  • 6.  RE: MLE2 Follow Program Bus
    Posted 02-16-2013 20:58
    Hi David,
    The system is following what it thinks is the next items to air. You can not change what it tracks.
