  • 1.  Dashboard Panel PGM select
    Posted 12-06-2016 18:25
    On Dashboard Carbonite Panel page to control a Carbonite Solo, is it possible to select an Aux output and send PGM to it? There is currently no PGM button on the ME, MiniME1, or MiniME2 buses and the Aux buttons select from them. Also, can you change the input select buttons to different sources on the Program and Preview buses? If not, can you change them on a custom panel so that I could make a PGM button to use for Aux selects?
    Jeff
  • 2.  RE: Dashboard Panel PGM select
    Posted 12-06-2016 20:38
    You have to map a PGM cross point to it.
    Also if you use the menu section -- live assist - busses then select the Aux and then internal to send out PGM this is also really quick.
