I am trying to get the input of an AJA Kona/Xena LHe card to work on one of our XPression systems.
The output of the card works fine, but when I try to use the input with a LiveSource shader the shader stays black. When you look at the hardware setup it tells me the Input is active the moment the scene is online, when setting the scene offline the status changes to initialized again. Can the in- and output of the AJA card be used simultaneously? I also tried a DeckLink Duo (one channel as output, one as input), and this works fine. Any ideas?
