  • 1.  Dashboard Control Page
    Posted 04-19-2013 19:44
    Need Some help.
    I have Dashboard 6.0 Beta running OK on a Mac Mini, running Windows 7 enterprise.
    Out of the Mac Mini "mini display port" using a display port to HDMI adapter
    cable. I am using a yellobrik CHD1812 HDMI to HD/SDI converter, taking the HD/SDI output into the Carbonite 24 input. I get the dashboard control page in the switcher.
    Everthing OK at this point.
    In the Carbonite I go MENUSYSTEMSMultiView dial in MV1VctlT :
    The view control comes on in dashboard.
    Everting OK at this point.
    Next:
    this is where I am having trouble.
    going to my touch Screen "PLANAR Model : PXL2430MW" :
    Coming from my AUX-7 to a yellobrik CHD1811 "HD/SDI to HDMI converter", then to the touch screen. out of AUX-7 is MV1 routered.
    have the MV1 in the touched screen but not the control page over it.
    What am I doing wrong
    PS My touch Screen is working
    HELP
    Dale
  • 2.  RE: Dashboard Control Page
    Posted 04-19-2013 20:10
    Hi Dale
    After selecting the the ViewControl layout in the MV menu make sure the OVL knob is set to the input that you have plugged the PC into. Then you will want to use the Clip knob to adjust it to 6.3%-13% depending on the Black Level settings of the converter. usually 6.3% will work just fine.
