  • 1.  Rename Memory
    Posted 01-16-2014 03:11
    Hi all
    I was unable to find a way to rename the Memories? Anything I'm missing? If not, is there a plan to make that possible? Currently just keeping a list of tasks/mems with their corresponding bank/mem combo.
    Iain
  • 2.  RE: Rename Memory
    Posted 01-16-2014 03:33
    Carbonite has no way to Name Memories at the current time.
    It is in the feature request Database, but we need to get more done in the DashBoard Interface to then add this once we are further along.
    Thanks for the post to let us know that this kind of feature is something that would be well received.
  • 3.  RE: Rename Memory
    Posted 01-16-2014 03:38
    Glad to hear its on your radar. Most of the time I'm using CCs(which I can name) to recall memories. However, every now and then I just need to recall manually. Renaming would be a handy feature.
    Thanks for the quick reply.
    Iain
  • 4.  RE: Rename Memory
    Posted 01-18-2014 22:24
    Iain a trick I do is this:
    I record say CC 001 and the only thing I have it do is select Emem Bank 0 #01. Stop recording the CC. Then I can "LABEL" the CC.
    Since each bank of emems can only have 10 total -- I use the first 10 CC of each CC bank corresponding to the emem bank. I use the remain empty CC to do other things like split screens, 2 boxes, 3 boxes, 4 boxes, and the ever poplar never used 5 box.
    Of course you can do it the old fashion way and write down each emem on a sheet of paper and leave it next to the switcher for reference, which is not a bad idea to do.
