  • 1.  Control of blackstorm clips with Custom Controls
    Posted 03-13-2016 23:57
    I want to play specific clips in Blackstorm with custom control. How do you specify clips to play? I can get the player to play via amp functionality, but want to play certatin clips. Is it part of Ross talk or a GPI function.
  • 2.  RE: Control of blackstorm clips with Custom Controls
    Posted 03-14-2016 02:18
    Put the Clip you want on the Channel you want -- via the DashBoard BlackStorm UI. Now when recording your Custom Control you can press the CUE button from the panel menu (or the CC editor DashBoard Menu while in record mode) this will then insert the CUE of the Clip ID or Playlist ID currently loaded on the channel.
    From the CC edit menu you can also enter the CUE for this and TYPE in the exact Clip ID NAME or Playlist Name.
