  • 1.  FLASH
    Posted 10-26-2016 19:48
    When i set up the onset. offset. and hold % for the flash and save the set it always recalls the set with the flash back to default.
    Isn't this part of the set save?
  • 2.  RE: FLASH
    Posted 10-26-2016 20:33
    It is part of the R State -- So after you set all of that up and have the switcher they way you want when it boots then you will need to Store the R State.
