Apologies in advance if this has been discussed before...
New 2ME Carbonite being installed in a flight pack... will be working in 1080i format... Does the Carbonite need to lock to Tri-sync? or can it lock to NTSC analog black?
I'm using Tri-sync and am questioning the NO LOCK when in 1080i/60... 1080i / 59.94 shows reference... all fine except the cameras are being a bit "temperamental" ...
If I'm understanding the set-up guide, I can only use analog black when working in SD format... in HD mode, it requires tri-sync... Is this correct? Or am I missing something along the way?
thx.
b.
