When you setup the AMP Device make sure under options that you disable the Eject Clip Command. Tria Does not need this. I generally disable the Roll Clip Function for Servers that I use for Wipes and insert the play command my self in the CC. The Roll Clip Option is also under the options Control.
The Tria does need to have (in the Configuration GUI -- separate application from the Explorer application) the AMP control enabled.
Two ways of doing the clip learn is either manually enter the Clip ID by using the CC Editor in DashBoard for the Cue Clip command. Or Load the clip into the channel manually from the Tria Explorer GUI then while recording the CC use the panel to "Cue" the clip. This will learn the ID.
Normally I would go with the Following:
CUE CLIP
Pause 5 Frames (as your well aware play with this till it is just right)
Play
Cut Key X ON
Pause Y (duration till CUT -- or Auto Trans)
ME Cut/Auto Trans
Pause Z (duration till animates out)
Cut Key X OFF
