Thank you Roberto, we are very proud of this product - it is the most successful Mid-size switcher ever :).
If you are asking if an FSFC can be used to convert an output to another standard - Im afraid the answer is no. FSFC's are on the input side and can only convert from an input standard to the switchers operating format. For output format conversion you will need an external converter - which fortunately we make also :).
Nigel
