  • 1.  How do you select PGM as a source for the Aux Bus?
    Posted 10-06-2015 15:33
    Hi All,
    I realize you can assign PGM to an output directly, but how do I go about select PGM as a source for the AUX bus?
  • 2.  RE: How do you select PGM as a source for the Aux Bus?
    Posted 10-06-2015 15:35
    You assign it to the Bus MAP. Normally I put it on the SHIFT side so that I don't waste primary side XPTs since you can not select PGM on switcher ME buses anyway.
