  • 1.  Carbonite and O1V96
    Posted 04-27-2013 08:34
    Carbonite with SMC 9901 doesn't retain the connection with our YamahaO1V96 mixer after powering down Carbonite.
    I have to go through the config steps on the Carbonite to get it to talk again.
    Yet it remembers the audio to video channel assignments.
    Something I am missing maybe?
    Is there any chance of audio mixer assignments being added to dashboard?
  • 2.  RE: Carbonite and O1V96
    Posted 05-02-2013 16:03
    Hi Peter,
    We are not able to re create this issue here. Can you describe your connections? are you using the serial port on the back of the frame or going through an ehternet to serial expander? If so what model of expander?
  • 3.  RE: Carbonite and O1V96
    Posted 05-12-2013 09:34
    Hi Les
    I am using the SMC 9901 and the serial port.
    I will test again and get back to you as we havent used the setup for the last few jobs.
