Hey guys, (probably Les.)
We just recently had our switcher upgraded to the most recent versions of frame and dashboard software.
We use a 25 frame TGA sequence as a media wipe to a rollclip-enabled video server with a cut under the middle of the transition. Before the upgrade, we used to hit the auto trans button, the effect would start and the clip started rolling about midway through the transition. In hindsight, it seems like the rollclip command was sending the play command to our video server at the time of the cut, or when the video source hits program.
Since the upgrade, we have noticed that when we hit the auto trans button, the video clip starts immediately, with the first 25 frames of the package covered by a transition. This leads me to assume that the roll clip function now sends the play command to the video server as soon as you touch the transition key as opposed to when the source is taken online.
Is anyone aware of this change, and if it was planned, or a bug as a result of the upgrade? Also, is there any way to change when rollclip sends the play command. We know you can delay the cut to video with preroll, but we cant seem to delay the play of the video server after hitting cut. I hope that all makes sense.
Thanks for the help.
