  • 1.  Trigger T2 Record Via AMP
    Posted 01-29-2019 17:57
    Is there a way to configure a device to trigger my T2 record channel? Trying to avoid using GPI/O to do this.Would love to do it via ethernet, but cant figure it out in the Com Setup. Thanks!
  • 2.  RE: Trigger T2 Record Via AMP
    Posted 01-30-2019 15:12
    HI do you have the Device setup and working? The Record command is done by Building a Custom Control to send record.
    #Acuity
