Can you give more description on the slide effect your looking to create? otherwise the reply may not fit you need.
However a basic element would have you use the State function to insert a state -- move the box where you like it and set another state insert a pause or hold. Then insert another state but with Effects dissolved as the mode and the Effects Dissolve Rate set for how long you want the travel rate to be.
