Hello, I purchased the Moxa 5150a N port to connect my Carbonite Solo to at TDC-100 Lance controller to run PBUS commands to some hyperdecks. Configured Moxa to match parity, baud, bit etc. Currently running out of the serial port on carbonite into moxa rs port data input and RS 432 to Lance. I'm not supposed to run serial port through network switch correct? It's just serial data cable to Moxa N Port and rs432 to lance? Not seeing connectivity lights on Nport like I did when configuring it with laptop.
