Second question about RossTalk -- When you make Sequencer Take IDs you would then want to make sure to assign those to Server Channels not Frame Buffers. Then with RossTalk commands when you configure the Panel you have to use the SEQI I Command and only specify the Take ID and leave Channel and Layer set to SEQ selections.
When you use the TAKE Command it always requires that you specify the ID channel and Layer. I will have to talk to the XPression Dev team to see if the server channels will work via the RossTalk Protocol this way. Or if we need to add some functionality. That said I have tried the VDCP App and it just works so I would suggest trying it.
There is also a Purchasable VDCP ShotBox DashBoard Application that also works.
#Graphite#Graphite#Graphite#Graphite
