  • 1.  Kipro / K2 Links
    Posted 10-05-2015 15:04
    I have Kipro units and K2 Units all on the same network with the switcher. Is there a way to do Clip Store on the Switcher?
    Example: If i have a videos in K2. Can i fire a macro on the switcher to pick a clip and play the clip.
    Thanks for any help.
  • 2.  RE: Kipro / K2 Links
    Posted 10-05-2015 15:58
    The K2s support the AMP Server Protocol.
    You can setup the device using AMP and then be able to assign Clips and cue them.
    http://www.rossvideo.com/pdf/cutsheets/acuity-interface/Video-Server_GVG(4820DR-670).pdf
    That link will show you how to configure the device.
    Here is a link that has a video for working with Clips and even animated transitions on Vision (same workflow applies to Acuity).
    By the way is this a single panel or multiple panel workflow? Where is this switcher located?
    #Acuity
  • 3.  RE: Kipro / K2 Links
    Posted 10-12-2015 13:09
    Is there anything i have to do to get the VTR to work. Its not letting me set that up.
    #Acuity
  • 4.  RE: Kipro / K2 Links
    Posted 10-13-2015 00:29
    There is no Native VTR protocol in the Carbonite.
    #Acuity
