  • 1.  Triggering Harmonics Video Server Using Carbonite
    Posted 10-17-2018 00:07
    I am currently running a Harmonics video server through Dalet, and was wondering if there was any information in regards to playback triggering through Carbonite. Before I had set up ProVideoServer using AMP, and was wondering if there was a similar setup, or really any information in regards to Harmonics and Carbonite.
    Thanks,
    Ryan
  • 2.  RE: Triggering Harmonics Video Server Using Carbonite
    Posted 10-19-2018 17:14
    Sorry Ryan -- but I am not aware if those video servers support AMP. Another option might be to use GPI triggers.
  • 3.  RE: Triggering Harmonics Video Server Using Carbonite
    Posted 10-19-2018 18:38
    Thanks Les,
    As a side note, I am trying to set up a GPI trigger from Master Control to fire a Custom Control. Is there anything I would need to know, or is it as simple as just assigning (and hard wiring) say input 34 to a GPI that is instructed to trigger said Custom Control. Like is there any type or length of signal that is needed from Master Control to the Carbonite that is needed?
  • 4.  RE: Triggering Harmonics Video Server Using Carbonite
    Posted 10-19-2018 18:41
    You can literally use a paper clip to tie it to the GND pin on the DB-37 and it will trigger the GPI. So assign the GPI in the dashboard menu to the Custom control you would like to trigger then test it :)
  • 5.  RE: Triggering Harmonics Video Server Using Carbonite
    Posted 10-19-2018 19:15
    I know the Carbonite is technically only supposed to automate with Yamaha audio boards, but do you think there is any chance the same setup procedure would work with a Calrec audio board?
  • 6.  RE: Triggering Harmonics Video Server Using Carbonite
    Posted 10-19-2018 20:26
    Calrec does not support the Yamaha Midi protocol. That said I do think we may offer a for sale DashBoard Application that does the Yamaha to RAP conversion that can interface with Calrec and also the SideSlide faders.
  • 7.  RE: Triggering Harmonics Video Server Using Carbonite
    Posted 02-26-2019 12:35
    I was doing some more research on Harmonics Spectrum X playback supported automation protocols. Again, I am trying to streamline playback functionality through my Ross Carbonite to the Harmonics Spectrum X playback device.
    These are the supported communications:
    Polaris Advance, Polaris Elite, Polaris Play, Polaris Live All Oxtel protocol automation systems (Ethernet or RS-422) Clip playback control via Spectrum API or VDCP (RS-422)
    I know Carbonite primarily use AMP or Rosstalk Generic, but could any of these protocols be used in a similar fashion via Carbonite over Ethernet connection. Maybe there is a software upgrade or conversion device that could help establish that communication. Or should I just focus on setting up GPI triggers?
  • 8.  RE: Triggering Harmonics Video Server Using Carbonite
    Posted 03-03-2019 10:29
    Have you tried the DashBoard VDCP generic commands with the server? Do they work? Maybe you can setup some buttons in a DashBoard panel to send commands to the server and then use RossTalk GPI events to trigger those buttons.
  • 9.  RE: Triggering Harmonics Video Server Using Carbonite
    Posted 03-13-2019 11:07
    Is there any information in regards to Dashboard VDCP, like a tutorial or written manual?
    Thanks,
    Ryan
  • 10.  RE: Triggering Harmonics Video Server Using Carbonite
    Posted 03-13-2019 16:22
    Ryan -- Try the DashBoard U video linked here:
    https://www.rossvideo.com/gallery/using-vdcp/
