That was probably due to the change in versions and the manuals changing
http://help.rossvideo.com/carbonite-02/Topics/Setup/Network/Net-Frame.html------------------------------
Product Manager - Production Switchers
Sent: 04-30-2021 15:24
Subject: how to connect carbonite black plus to control panel 3x
Link seems to be broken.
Marty Hill
OAK HILLS CHURCH
Sent: 02-19-2020 07:16
I'm not sure exactly what you are asking.
Panels connect to the frame using a network connection. You can set the IP address either on the panel or using Dashboard. If you have a look at the online help you can find instructions and info about how to reset iP addresses if you need to. It's a really good resource for finding out how to do most things Carbonite related. https://help.rossvideo.com/carbonite-02/Topics/Setup/Comm/Ethernet.html
