  • 1.  Slide Effect with short Audio
    Posted 04-17-2019 18:22
    Hi, everyone.
    I would like to carry out slide effect(which Less helped me to do so) with Audio track. For an example, I have seen that recalling 2 ; 3 or 4 key boxes comes with Audio track(like key 3(1or2) appears with short sound) in one of the channel. Is it possible to accomplish such an effect in Ross Carbonite ?
    Thanks in advance
  • 2.  RE: Slide Effect with short Audio
    Posted 04-23-2019 12:05
  • 3.  RE: Slide Effect with short Audio
    Posted 06-17-2019 18:38
    You might consider (permitting you have enough media Store channels available) adding the audio WAV file to the media Store and then adding that to the Memory (attributes General Tab).  It would recall the audio file when you do the Memory recall.
    Otherwise you would Build a Custom Control that will recall the Memory for the slide and then add a pause and fire off the Audio File.
