Not sure -- does the KiPro allow Record commands via a GPI trigger?
If so then all you have to do is pick a GPI/O pin -- set it to GPO function and match the desired input type of the KiPro.
Then make a custom control and insert that GPO trigger -- now you have button that can trigger it.
