  • 1.  Multiviewer Green Line
    Posted 07-02-2019 21:33
    I am getting a green line at the bottom of multiviewer, but only when the tally option is set to Label.  When I change the option to Box the green line goes away.
    When I route the multiviewer to another monitor I get the same result.
  • 2.  RE: Multiviewer Green Line
    Posted 07-02-2019 21:53
    What layout configuration are you using?  What version is the Graphite running (status page in dashboard has this)? and what video mode/standard are you operating in?
    #Graphite
    #Graphite
    #Graphite
    #Graphite
  • 3.  RE: Multiviewer Green Line
    Posted 07-02-2019 23:01
    Layout H2-4-4
    Version: 2.1.0.17332
    1080i 59.94
    #Graphite
    #Graphite
    #Graphite
    #Graphite
  • 4.  RE: Multiviewer Green Line
    Posted 07-03-2019 13:41
    So it is not a "green line"......It is some kind of "stuck in memory" line that does not have video on the Bottom 4 box in the 2-4-4 or in the 4-2-4 or even the 4-4-2.  The Bottom most set of 4 windows always seems to pick up left over data in the empty line it has at the bottom of the box.
    Quick work around to make it "go away"....Change the layout to a 1 Box....Change the source of the 1 Box to Black.  Now Change it back to the 2-4-4 layout and change your Box 1 back to the source you prefer --- You can make a custom control for this :) so that you don't have to constantly deal with this while we look into how to resolve it.
    #Graphite
    #Graphite
    #Graphite
    #Graphite
  • 5.  RE: Multiviewer Green Line
    Posted 07-10-2019 18:12
  • 6.  RE: Multiviewer Green Line
    Posted 07-16-2019 16:55
    Les,
    I made a CC that changes the layout to single box, changes source to black, then changes layout back, and changes source back.
    When I run each event in the CC one by one, it corrects the issue.  But when I run the CC all at once it does not fix the problem.  I have even put pauses up to 20 frames in-between each step in the CC.
    #Graphite
    #Graphite
    #Graphite
    #Graphite
  • 7.  RE: Multiviewer Green Line
    Posted 07-16-2019 17:34
    I just built a CC for this and used 60 frame pauses between each event:
    MV to 1 Box
    Pause 60 frames
    MV Box 1 : BK
    Pause 60 Frames
    MV to 2-4-4 layout
    Pause 60 Frames
    MV Box 1 to ME 2 PV (or what ever source you prefer)
    #Graphite
    #Graphite
    #Graphite
    #Graphite
  • 8.  RE: Multiviewer Green Line
    Posted 07-17-2019 21:04
    Thanks Les,
    Upping those long pauses all the way to 60 frames did the trick : ]
    #Graphite
    #Graphite
    #Graphite
    #Graphite
