  • 1.  Script Set Countdown Timer
    Posted 04-18-2013 19:03
    Has anyone made a script to set a countdown timer to a specific date and time?
  • 2.  RE: Script Set Countdown Timer
    Posted 04-19-2013 14:01
    The basic command to set a timer start value is: clockTimer.StartAt = "00:01:00.0"
    You would also need to declare your timer variable: dim clockTimer as xpClockTimerWidget
    I have set specific times to count down from (ie: 3 mins, 2:30, etc), but with a little creative scripting you can probably set a variable to use the system time and date to set the StartAt time.
  • 3.  RE: Script Set Countdown Timer
    Posted 04-30-2013 19:24
    Thanks Brian. This is what I have so far but not sure why its not working.
    dim setTimer as xpClockTimerWidget
    dim timenow as xpClockTimerWidget
    Dim intHour As Integer
    Dim intMin As Integer
    Dim intSec As Integer
    Dim TSecs As Long
    engine.GetWidgetByName("bloomsday_start1", setTimer)
    engine.GetWidgetByName("nowTime", timenow)
    TSecs = DateDiff("s", timenow, "09:00:00.00")
    intSec = TSecs Mod 60
    intMin = (TSecs / 60) Mod 60
    intHour = ((TSecs / 60) / 60) Mod 24
    setTimer.StartAt = intHour - 1 & ":" & intMin & ":" & intSec
    setTimer.Reset
    setTimer.Start
  • 4.  RE: Script Set Countdown Timer
    Posted 05-01-2013 14:53
    Richie,
    Try this:
    Dim TSecs As Long
    Dim current as Date
    engine.GetWidgetByName("ClockTimer1", setTimer)
    current = Now
    TSecs = DateDiff("s", Hour(current) & ":" & Minute(current) & ":" & Second(current) & ".00", "11:00:00.00")
    setTimer.TimerValue = TSecs * 1000
    setTimer.Start
