I'm having a reoccurring issue where after Graphite has been running for a couple days and not used, the frame loses its network connection. At this point the NIC on the Carbonite only has green light blinking, not amber, and Dashboard and CB2 panel can't communicate with it.
I have default / static IPs.
Has anyone seen this? My only solution is to do a full shutdown, then it comes right back up.
