I've started to use TSL UMD for tally in our facility, for on-camera tally units (we don't have CCUs), replacing an arduino I had plugged into the tally port of the Carbonite.
Anyway, I came across an issue where the Carbonite isn't using the addresses specified, but rather the input number is being sent out as the address. So, if I have camera 1 on input 1, and I specified address 5 for input 1, it's actually using address 1 instead of 5 (seems to be a bug). So to get around that, I've moved camera 1 to input 5 so that the tally information comes through on the right address. That works fine and gives me what I want, but, the TSL addresses appear on the built-in multiviewer windows, and it's confusing to look at the labels ("1:TSL 5" for Camera 1, "2:TSL 6" for Camera 2, and so on). This would probably happen if the addressing worked properly too.
Is there a way to hide the TSL labels on the built-in multiviewers?
James.
PS the reason for the specific addressing is the way our facility is set up with two studios sharing a control room, and not something that can be changed.
