Hi Simon,
Logging to USB is different from EDL. This logging is for diagnostic purpose. By default, it logs to RAM, which means it gets lost after the frame is powered down or rebooted. To save and extract the logs, there is an option to copy the logs from RAM to a USB drive. Or to log directly to a USB drive.
EDL saves the sequence of switches made with respect to time. This is to aid in post production.
Aaron
Sent: 11-24-2021 02:40
Subject: Switcher not seeing USB drive
Can I hijack and ask what the logging to usb does ? Is it like the EDL ?
Simon Dargaville
Sent: 11-23-2021 14:58
If the Drive can not be written too only read then it sounds like the USB flash controller has locked it .. probably due to no longer having the available error blocks. Unless you are having issues that you need to track with Tech Support I would turn off the Logging until you run into something that needs to have this turned back on. That will reduce the number of write cycles tremendously..
Sent: 11-23-2021 10:09
We do have logging enabled. The drive can be read on other computers, but now the Carbonite does not recognize it. We will try another drive.
Stephen Flach
Lead Broadcast Tech Engineer – TUVS
AT&T University
100 E Royal Ln Suite 105
Irving, TX 75039
Mobile: 972-207-9598
Sent: 11/22/2021 4:08:00 PM
Subject: RE: Switcher not seeing USB drive
Did you have Log to USB running on them? That could accelerate the life span of the Flash Memory as it would be constantly writing to them.
Sent: 11-22-2021 15:31
I have had multiple occurrences of USB thumb drives in Carbonite Ultras suddenly, being read only. I tried reformatting on another computer, but the drive can't be reformatted. Is this a known problem, or is there a known fix?
STEPHEN A Flach
ATT
Sent: 05-26-2020 00:14
Hey Michael, once you've got a USB drive in the frame you can FTP into it to update stills and manage the names of your switcher sets which saves having to get the USB drive from the frame.. (I use either file explorer or Filezilla).
