  • 1.  Custom DVE
    Posted 09-26-2016 15:24
    I know I have done this before in training but have not had a need to do so since. I have a 2 box setup with a camera shot and CG. I would like to come back to the camera shot using a DVE transition to bring that box fullscreen. I am just blanking on how you set it up.
  • 2.  RE: Custom DVE
    Posted 09-27-2016 00:43
    You'll need to use an effect dissolve for that. The quickest way to do it is:
    - recall the memory that provides the boxes
    - turn off the key that shows the CG
    - reset the key that the camera shot is in to make it full screen again (just press the "Reset Key" button on the multipurpose button area - top left of panel)
    - set your memory to store as Effect Dissolve (even set a transition time in there too; easiest to do this in Dashboard)
    - save the memory
    Then, you can recall the 2 box memory, then recall this new memory, and it should move to full screen. That's provided you have recall set to "Memory" or "Effects Dissolve".
