  • 1.  Elbow cg
    Posted 09-11-2019 18:50
    Hi, There.
    I had created every detail of squeeze back. Have created DVE Key1 with PGM in it and KEY2 with CG in it on MiniME4, and can not to take MiniME4 to ON AIR. Can anyone know what a reason for that?
  • 2.  RE: Elbow cg
    Posted 09-12-2019 06:49
    Which ME or MiniME are you using to make your squeeze back? It seems like you have a re-entry loop or timing issue happening, http://help.rossvideo.com/carbonite-02/Topics/Operation/Basics/Re-Entry-Timing.html?hl=re%2Centry
    If you have both boxes made on MME4 that means that Pgm is on MME4 so you can't take MME4 back onto PGM as it would "feedback".
  • 3.  RE: Elbow cg
    Posted 09-12-2019 06:57
    I made both boxes on MiniME4 , key1 as DVE which assigned PGM, key 2 as a CG.
    How I can take MiniME4 to OnAir whilst PGM on it as a squeeze back.
  • 4.  RE: Elbow cg
    Posted 09-12-2019 07:10
    The problem is having PGM in the MME4 DVE and then trying to put MME4 back onto PGM.
    You will need to use another ME or MME in the box.
    I don't know how many MEs you have or how many keyers you are using on your PGM row. You could - for example - put MME1 into the DVE box, cut your show on PGM until you need the boxes, cut to MME4 on PGM and then cut your box on MME1 until you are done with cutting in the box and then go back to PGM row to cut.
    Or you could simply cut the key 1 box sources (if you don't need keys in the box).
    Or you could cut your show on a second ME which is also going in to the DVE box then cut between - for example - MME1 & MME4 on PGM.
    Or you could use MME4 as your main Program output, put your PGM ME on MME4 ubtil you want it in the box and then cut BGD, Key1 & 2 to put the boxes on & off.
