  • 1.  Reset mediawipe transition
    Posted 06-15-2019 21:17
    How do you add a command to a CC that at the end of a media wipe the transition resets to Dissolve?? Right now it stays on mediawipe
  • 2.  RE: Reset mediawipe transition
    Posted 06-16-2019 13:57
    I might need a little more information on how you are operating but I will assume you are using CCs to cue and run the media wipe effect?
    If so then you add a pause at the end of the CC that is a few frames longer than your Media Wipe duration (length of the animation sequence plus a few frames) and then you can add commands for setting the next trans area to Dissolve.
