Hi Glen,
Oh, then I'm using a beta-version then? Can I notify you of a bug for the actual release?
When you have a group with various children-objects in it and you try to delete the group you get an Exception-error.
I'm currently using Xpression 5.1, build 2505
Also one remark about the API-documentation, where I have been struggling to get it right is when you are using the SetKeyFrameTCB-method.
One of the properties is telling you to use the string of the keychannel to use. In the documentation it is shown as kc_ScaleX where you actually have to use Scale.X, so maybe this could be corrected as well?
Thanks,
Kenneth
