  • 1.  SKAARHOJ Tally System Integration
    Posted 04-01-2020 15:38
    We have upgraded are facility from a BM ATEM to a Carbonite Ultra. We had been using a
    SKAARHOJ tally system with out 3 JVC 890's and the ATEM. It worked quite well and was simple to install and setup. Does anyone have insight as to how to implement this with a Carbonite? It's in place and if we could get it set up it would be a huge help.
  • 2.  RE: SKAARHOJ Tally System Integration
    Posted 04-01-2020 15:44
    Hi Jeff,
    Have you reached out to SKAARHOJ ? The Carbonite supplies the TSL UMD Protocol v3.1 over TCP/IP or via the one RS-422 Serial Port on the back.
