We have a Carbonite+, which I have upgraded to v12.4, with a surface connected over a serial link. I've been playing the 'Panel' section under Dashboard (which is a brilliant addition, Thank You!) as I can adjust Tallies etc without having to get access to the surface.
Is/Would it be possible for a 'Panel' to have an option to mirror the physical surface that is connected, so that the BusMap on the Physical surface can be adjusted, rather than just the BusMap of the Virtual Panel, or is this information that is only stored inside the Surface?
Cheers
James
